jallen355
hey jallen, the only prob with those is the Ipod has a 1 volt or less output for the audio. most low end head units have 2 volts and a high end unit will have 4 volts or more.
even if you turn the volume on the ipod up and the gain on the amp all the way up you will not achieve the amps full potential output. The audio cable you have pictured above will work fine. you may want it to be louder though.![]()
Yes. I've considered that. If it doesn't work out, I'll consider adding a head unit mounted on some sort of custom fabbed "drop down from under the dash" bracket, or something. I really just don't want to dash mount a unit.
