Powder coat them to match the boat. Make sure you use the 1/8" backing washer. Thy tend to pull out with a ton of air pressure.
Originally posted by wickedrister:
Gus, Where is the best place to get merc decals. I want a white one for the pick up truck.
( very nice job ) I like very much, I like doing glass work ( gifted I have never itched ) for a first job you did greatOriginally posted by wickedrister:
Thanks ! This was my first try at doing nasty old fiberglass workItch Itch Itch. It's not a factory job but I think It's turning out OK. Kind of funny that all this work was done because my trim cylinder needed rebuilt.I was removing the gas tank to access the lower motor mounting bolts when I found the rotted stringer system, standing water and the saturated flotation foam. Now after all that work I still need to pull the motor loose and take the trim cylinder out for rebuilding. Wish I had a 135 or 150 to hang back on her. 41 mph is just to slow for this little boat. 55 to 60 is what I hope to see one day![]()
