I'd remount the motor on the jackplate up 2" so that the prop shaft is even with the pad at the top of the travel that's how my boat came set up from Roberts Marine.
I find I don't use the very bottom of the travel of my jackplate anyway as having the prop 5" down when starting out or tubing is too low. I do all my starts with the prop about 3 -4" below the pad and raise it from there as the boat accelerates. That's also about where I set it for tubing. So I think you are too low if you do your starts with the jackplate all the way down as you will be about 7" below the pad at your current set up.
I hope my discriprition of my modification to the jackplate made sense, as you will also benefit by removing the bottom 4-5 " of flat area that drags in the water.
Maybe you have a motor issue too, but you still have these two set up issues to clear up IMO.
Not sure if this has been done or is just a dumb suggestion, but is there any chance the motor is starved for fuel on launch? If there's an internal flap of rubber loose inside the squeeze bulb or flap of something stuck in the fuel filter or something like a piece of cling wrap in the gas tank, maybe when there's a sudden change in fuel GPM that "thing" is moving around and partially restricting fuel flow. If anything is not letting the motor take exactly the amount of fuel it wants exactly when it wants it, I'd think that would result in poor hole shot. Perhaps try a portable gas can with brand new length of 3/8" gas line shoved in the top and connect that to the motor with no bulb or nothing in the line. Then get a buddy to hold on to the gas can while you punch down the throttle. If it still does the same thing then it's likely the fuel delivery system is fine, but if the thing shoots out of the hold like never before then I'd be changing the lines, filters, and cleaning out the tank.
Thanks that's a good idea trying a test can, fuel psi has been tested but not under a load.
I agree with the consensus that your motor is too deep. Raise that bad boy up and see what happens...I think your performance across the board will go up AND it will get easier to drive.
Not sure how to raise my motor without getting a static setback bracket, which I don't really want more setback since main use of the boat is watersports. My motor is mounted in top hole and jp is mounted in top position on transom plate...
