Ramifications
i meant a paying job....![]()
You mean you're not paying him for all of the time he has put into this for you? I think a little compensation is due when your project is completed
Maybe join in on the first rideWelcome to the Checkmate Community Forums forums.
Maybe join in on the first rideJeff , after viewing your pics of the bottom ,and the strakes are you sure that is original with no mods added .? Just curious .................and the reason being is........ there is to much facial surface ( strakes) squared off from end to end with no scarf joint .
Jeff , i aploogize and should have worded that differently and with that in mind the cut on the liffting strake where it drops looks a little crude to me just because it is so squared off and was this done by the factory or somebody just trying to make the boat faster and in your pics it looks like you can somewhat see ply in the stepped part of the lifting strake or is that just me .im not sure about mods...i was told by the boat repair shop when i had the stator replaced the boat had a race set up...he thought I had a XR motor too...
can you explain a little more what you mean by "facial area" and there being no scarf joints?.
I've been following this thread regularly and I would bet money on all that hook came from it sitting on the trailer during the recore. I am restoring an 87 Hydrostream Vegas XT, which is a mod V tunnel hull, that is sitting on a roller trailer and you could see the hook being put in the bottom from the rollers from the core being rotted. Fortunately with the hull design I was easily able to set the hull up on some blocking on the outer sponsons and lift it off the rollers. Once I did that the hull came right back out and the hook was gone and from there I started the recore.
Jeff , i just left a voice mail with you and will call back, and its all good , and do you remember what i told you a-while back ....... #1st it is just a dumb piece of fiberglass and you are smarter then it , and always will be .# 2 actually should be first and do you remember what i told you about something going to s**t how it can always be fixed no matter what......... because that is the beauty of it all . Jeff , it will be fine ,and at this point in time this is nothing compared to what you have already done or achievied during this project .well it all looks like it still has the factory speckled paint on it?? so i dont know, but there is no ply showing anywhere, no cracks other that the bow. Gel Seems pretty solid....just some nasty hook...and we all know where that came from...
Lets talk more about what i should do there....If you could call when you have a moment.....![]()
Kalugs 22 , Hydotreams are one of my all time favorite boats to work on or should i say fun considering i have done three in the last two years which all had to have a total recore, transom , ect ,and hopefully another one this spring ,& yes at this point in time after talking wtih Jeff , i think he is well aware of the fact that this problem (hook) might have occured from the trailer itself , and is........ in the process of redoing the entire bottom ( blueprinting ) the hull making sure everything is straight along with a few other things .
geez man...since you have been following this thread why didnt you speak up before?...thats what this forum is for ...discussions...and yes most not all of the hook does appear to be self inflicted, again, if you have been following this thread you should have seen I already stated that...
Your post is more insulting than the "I told you so guy"... no one likes that dude....but hey, thanks for finally chiming in...![]()
I not frustrated my friend, discouraged yes, but not frustrated, be careful before you speak....
He actually states he knew it was going to happen and second, hind sight is important, but hind sight is not what this was.
This is a forum open for discussion, comments and to lend a helping hand, so please tell me my shoes untied, dont let me fall and then tell me you knew it would happen...On the other hand, Its not his fault I fell...
And if that comment would make someone not post things...i think we all better go home...hes a big boy, let him speak up if he didnt like my comment as much as I didnt like his....and, yes, if the post is I told you so, then i dont want you to post anything...
I don't care about your post, it's your thread do what you want, trust me it won't stop me from chiming in, and it was in no way supposed to be an "i told you so", I was just sharing of a similar problem that I had with a roller trailer during a recore I just happen to be standing in the right place at the right time. I have been following your thread but not from the beginning you were already recored before I started reading, I wouldn't have intentionally not shared something like that. We are all here to help and be helped! Either way I like the boat, it should last you a long time with the quality of work your putting into it.
I, agree 100%Good stuff right there!!! The boat is coming together nicely, great job!!![]()
are we having fun yet my ole friend ....another example of what you dont know you have until you get there...
some old repair didnt even know had been done...
