must of bumped somthing huh![]()
vacuum bagging.... ensures proper layup and eliminates any air bubbles or excess resin.
Jeff , for your type of appllication bagging is really not necessary considering the weight of the fabric which in your case actually would be a waste of time even though bagging can be very useful at times it really is not needed considering you have the boat fliped . Jeff , i think you will find the primer to sand like butter and no need for special Activator's or reducer's other then Acetone & MEKP. ( Catalyst )
how are your arms and shoulders holding out? looking good! thinking of doing the bottom of mine this winter.
Jeff, very coooooooooooooool , and your painter & i think alike considering i always put everything in #220 before paint . Hey bro .....the easy sanding comes after breaking the surface ,and at this point in time the rest should be a walk in the park for you ,and just curious are you doing the actual spraying of the Primer ........and if so the bigger the tip the better which means you will be able to push more material at a faster rate but non the less i will give you a call tomorrow ,and to tell you the truth i actually am very curious (excited) to see what type of gains (mph) you have achieved thru all this hard work .
Wow guys , i just noticed i have moved up the ladder to Convincer Status with mor Rep power .![]()
Ha Ha Hastill got you beat....![]()
BADBK , Bagging is always a good idea and it looks like you used a Venturi for bagging the bottom of that boat or was it an actual Pump ?
Jeff , whats going on , and we the people need an update .![]()
