ballardnboyz
first .
and by the way...I did start with 220....the hi build was all 220...just the primer he used was wet 400...
first .
And with that in mind i guess he really didnt spray or put much primer on considering .......once again you wrote me that you where already blowing thru in some areasand by the way...I did start with 220....the hi build was all 220...just the primer he used was wet 400...
 boy that sure was a waste of product , materials , and Time . W O W !
And with that in mind i guess he really didnt spray or put much primer on considering .......once again you wrote me that you where already blowing thru in some areasboy that sure was a waste of product , materials , and Time . W O W !
 ...im going back to the shop now and DA down the deck...need to move forward in this crazy a** resto!!!!!!
...im going back to the shop now and DA down the deck...need to move forward in this crazy a** resto!!!!!!Jeff , in regards to post #456 you wrote i am glad he sprayed over the high build as it really didnt fill like i thought, and in your last e-mail you wrote my painter should have put the primer on a little heavier , and i should have used guide coat , and with that thought in mind was the bottom that far off from being ready for primer ......considering you can spray up to 50 plus mills wet on wet to dial everything in..... but non the less it is very obvious your painter really did not have you order enough material to do the whole job period .
Good luck on the rest of the prioject and take care . See Yah................
 hows the boat coming along?
 hows the boat coming along?sorry men...been busy with work...heres the bottom finished painted....
