OFFSHORE GINGER
Banned
Paul , manual gets old quick ,and i often go that route depending on the surface but machine is really the only way to go .ive got a manual one of those...3 ft hook and loop paper,want to use it?
Jeff , are you using the reddish brown cream hardner and please do not take this the wrong way but did you center that board ( ply )on the in-line sander / file board ....and if so cool .................& are you going to use guide coat ?
Jeff , its all good but you really need to center that board and the reason being is .....less vibriation to the hands / wrists , and less wear and tear on the inline sander itself / file board ........................ Jeff , 99 % of the time it is really hard to calculate on just how much material ( p-77 ) is really needed because every surface is different or should i say sand on / sand off and once again general rule of thumb is ................if it is high (sand ) and if it is low ( fill ) and maybe ................you just might want to order another gallon of P-77 on monday .................just a thought and i will give you a call tomorrow afternoon ..........................Take care my friend .......yes, thats the stuff they sent, the reddish brown..is that good?...I did not center the pad on my new OG sander...guess i will be in the am....
havent done any real sanding yet...was a long day, very humid and rainy today...slowed this stuff down a little..nicer tomorrow...I used a half gallon of p-77...that right? Had to build those new strakes up a little to keep them in line...
yes what OG saidJeff , everything is coming together nicely along with the Strake's ,and once again l@@king g@@d .
I was just joking OG,last time i used it was on an old 69 donzi someone decided to sandblast...what a mess!Paul , manual gets old quick ,and i often go that route depending on the surface but machine is really the only way to go .
The boat is coming along nicely!!!So by sharpening those corners/edges on the strakes that gives you better lift?
i wont say anything!![]()
