yellowfiero88
Got the hatch blacked and primered again friday night. It looks real good and should be ready for paint!!
Water testing was a ordeal to say the least.
#1~ Lost a wheel bearing on the way to the lake. New items from northern tool. Fresh grease before we left. Guess poo happens
#2~ Shift interupt was grounded to the head. Turns out the heads are not a good enough grounding point for it. Easy fix, put ground to block and shift problem was fixed!
#3~ Lost water pressure after a high speed run. I shut it down during the run as I saw the temp creeping up. Upon inspection, supply hose between PS oil cooler and thermostat housing would crush when motor was fired up. Brand new SEI installed impeller but I am thinking for some reason, it failed.
Boat did run good and the nose cone did help in how it goes through the water. I had it up to 5500rpm when I noticed the temp coming up. I was not looking at the speed so I have no ideal what kind of speed I was going. There was lots of chop so I was watching water conditions and oil and temp gauges. BTW, I had cooler, tools, big duffle bag of clothes, etc, The entire nose was full of stuff plus me and Megan and she still ran strong
Hopefully, it will be better conditions next weekend and I will be able to run it without any issues!
