Hayabusa
Its a awesome prop....I predict smiles. Are you gonna buy it off the bat or get it on the test program first?
I've got it coming through test program, Brett predicts the same
Little over 20 hrs on the 400 now & took it out yesterday early for some running with a buddy settled in at 78 mph & 6800 rpm with my 24 Bravo at 1" below, best i've been able to do on & off for the past 5 hrs that i've put on the 400, got a couple of diferent props coming my way to test & see if i can do any better, but what i like best of this Merc/Check combo is that i can run with 4 on board, gear & beer+ 3/4 fuel on board at 70 mph & 6300 rpm.....thats a blast
Thanks for the updates Hayabusa. You use your 2400 BRX the same way I do: mostly for hauling people and beer, but occasionally for hauling ass.
Hayabusa- I wanted to check in and see how you were feeling about your results (78mph), and if you think there is any more in it(setup, props,etc)?
I mentioned before that I am considering making same investment(I have a '14 2400 LD), however I was fully expecting you and JJG to both be well north of 80mph(I was thinking 82-83). I am currently at 74-75 mph consistently with the 300xs, so scratching my head a little now if worth the $$$.
Thoughts?
crazy right?
[Did you "trade in" your 300xs directly through Mercury? Trade in with your dealer? Or did you keep your 300xs?
crazy right?
WICKED
Cool! Now get a 26 blaster....lol
Update: took my Check out this morning for some prop testing, striped it to bare minimums & went out by my self with 3/4 fuel in the tank & this is what i got, back to back runs: my worked Bravo 22 pitched to 23.5": 76.4 mph @ 6790, my Bravo 24 pitched to 24.5": 77.8 mph @ 6800, BBlades OB/F 24 actual pitch 23.3": 78.2 mph @ 6890 & 0" with the pad, the BBlades Blaster 24" true pitch 24": 80.3 @ 7090 & 1" above the pad.
KCT11 you were right, what a blast it is driving this prop, lots of fun gets on plane fast, pegs at 6500 rpm geting on planeWICKED
The Blaster holds the bow better than the rest of the props, the OB/F coming in 2nd. At 80 mph the BRX requires your full attention.
ChuckB, can you post the pic of the recall i sent you? I've got to get around to contribute so i can post some pics, thanks.
Im seeing around 150 more R's from my Bblades version of the FS and its a little larger diameter then the OB/F but still pitched at 23.3
How is the hole shot on the blaster ? Does it want to cavitate a lot ?
Got to find a way to squeeze some extra ponies to run that 26![]()
