I have a question as to what lower unit are you running. Is it the new sport master or the other standard version.
You have plenty to spin it. 2 inches of pitch is 300 rpm and it might not cavitate as much on take off. If I had that thing I would put a 28 on it, you might be buzzing past the sweet spot of the motor.
Why not install a quality tight fitting bow cover on it and get your easy 5 mph speed increase? I know, snaps on the gel suck, but nothing frees up speed on an open bow like closing that area off...
It's the Sport Master 5.44" od gear case, 1.25 prop shaft.
The reason I ask is that the sport master is not really necessary until you get up around 85mph. I have a 21 pulsare with a torque master lower and run 82 to 84mph with no blow out. My boat needs a good amount of positive trim to run top speed. not sure about the 2400. If you run a lot of trim the sport master will actually be slower as the nosecone sticks down lower into the water than the torque master does. That being said you are running very high on the transom and Im not sure how the low water pickup works on the torque master. Im running an inch below the pad and get plenty of pressure as there are pickups in the nose of the drive just not sure that it would do the same up at the height you're running. It is possible the torque master could be faster unless the height/water pressure becomes a problem. Just a thought. Steve.
What's the RPM limited to?
Good though, before I bought the 400 i was running a 300 Pro with the std 4.88" gear case & like you I had to run lots of positive trim to keep my bow in good form to get my best speed, with the Sporty i run less positive trim to keep my bow were she likes for my best speed i believe the length of the gear case gives me more arm for leverage to keep my bow right were it needs for best speed with less trim angle, the low water intakes on the Sporty sit more than an inch below the ctr line of the gear case & i have run as high as 1-1/2" above the pad with no water pressure loss, I'm also at 13" of set back witch helps keep plenty of water to the intakes.
A friend of mine who owns GDS Canvas in Ft.Lauderdale built me a nice tight fitting bow cover & i took it out for a try early today, 6:30am for calm waters & to avoid water traffic on the intercostal, did several back to back runs with & with out the cover with the same result: 81.5 @ 7160, i think i'm hitting the limiter.
Initial hole shot is slightly off from the OB/F, cavitates a bit on the initial opening of full throttle but once it grabs it seems to accelerate faster than the OB/F, the 400R has a hell roar coming on plane at 6500 R's, frigin awesome![]()
What is their version of the FS? their Bravo 1 with vent holes? I'd like to try one from them, how do i identify it?
If my math is correct, you have gained 10+ mph w- the 400R over the 300? And it sounds like there might be a few more mph left in the set-up? How's the handling? Are you happy w- the gain vs the $$$ spent? Boat looks great!
I had them modify a std bravo by cutting the tube by 5/8" to match the FS and also reduce cup height. No vent holes, really no need for more cavitation on hole shot.
Problem with the blaster is the continous exhaust over the blades good for 2 strokes not so much for 4 strokes due to the torque difference.
