atc250r
Sounds like you've got it figured out. As for the fuel, if it smells like its gone bad I would sneak a couple of gallons at a time into the used oil container at WalMart. The one around here has it sitting out behind the auto center and you can just walk over and dump it. If its not bad smelling I would dump a gallon or two in with each fill up on my car. Is a 300XS what you're planning on running? Eventually I'd like to hang one on mine. What kind of speed would you expect with one? 75'ish?
Also, the hull is only rated to 250 per the plate...I don't want insureance problems. I originally thought the starflites and starliners were 300 hp hulls? Anybody know what the story there is?
, going to get cleaned up
