As you sand each color the water will turn to that particular color.
Thanks for the kind words everyone! Seeing the amount of work some of you all have put into tearing your boat down to nothing this is a walk in the park. I'm figuring hit it with 1000 tomorrow, 1500 Friday, and fire up the buffer for a long day on Saturday. If the weather cooperates Sunday I might be able to finish it up then and start reassembly next week.
That's what has me a little concerned Robbie, the red isn't really turning anything red as I sand it. The black and white are though. I've been using a gallon bucked filled with a hot water/dishsoap mix to dip the block in every few seconds and hosing the residue off the hull/deck well before it dries.
John
Finished doing the first wet sand yesterday (800 grit). Put in a little over 3 hours to get everything from the rub rail up done. One concern I'm having is that when I do the black strip or the white portion on the deck I immediately start to get the corresponding color in the water but with the red I only get a white or very slightly pinkish coloration on the paper and in the water. I was getting the same result with the two cooler covers pictured below and they came out pretty good. Should I keep sanding the red until I get some red out of it? Should I keep attacking with the 800 if I need to get the color out? If I need to I'll go get some 600 and take one step backward rather than go forward and get an inferior result.
John
I guess you know that if the color is in the water then you have gone through the clear gel. If the clear is completely oxidized you have no choice if you want to get the shine back. The down side is it oxidizes that much more quickly in the sun.
Hit it with 1500 tonight and gave it a thorough wash again. Some overtime came up at work so I've gotta work 6a to 2p tomorrow but I should be home by 3 and will start buffing then.
John
