Two gallons of resin? It will be more like 7-8 by the time your'e done. Trust me on that.
Glad to see you back at it!! Good luck!!Since you bought supplies from Mertons http://www.mertons.com/Epoxy/polyester_Resins/quantities.html here's a go by for quantities:
Figuring Quantities
One Gallon of Polyester Resin will saturate approximately:
3 sq. yds. 1 1/2 oz. Mat3 sq. yds.24 oz. Roving1 2/3 yds.38 oz. Stitchmat3 yds.24 oz. Stitchmat6 yds. 10 oz. Cloth9 yds6 oz. Cloth
wow! never used poly...i seem to be getting 1 1/2 to 2 times more than that coverage with epoxy....![]()
Lawson if you decide to go over to epoxy it is never to late and these people offer great priceing for a five gallon system which includes the hardner which actually is a 7.2 gallon kit ,and might i recomend there # 635 which will give you the most bang for the buck , no stank , and a longer pot life which means more work time . http://www.uscomposites.com/epoxy.html Lawson if you do the math in the long i think using Epoxy will be your best bet .![]()
Have you checked your core? I see a lot of black on the bottom that would be suspect of rot.
I used 1708 with both epoxy and poly on my restoration. I'm not an expert nor a scientist but I've learned that you can just about make anything work...as long as you don't half-ass it.
Rule of thumb: Polyester resin will not bond to epoxy.
Good luck!
well said robbie , and lawson be sure to always use a fillet filling in ALL voids made from Cabosil and resin ( putty - peanut butter consistency) using a hobby stick making a cove for the fillet , and are you planning on doing your layup all at one time considering more then one thing can be pre made and tabbed in after the fact .Looking good Scott!!!3/4" ply is good for the knees, make sure you round the edges so the mat will conform to the radius/edge. That goes for the stringer and braces as well.
Looking at your pictures you might need to grind out the remaining bondo where the floor and hull meet. That way you ensure a good bond. Don't forget to do what OG mentioned as well (post#56), makes life easier when you start the layups.![]()
