OFFSHORE GINGER
Banned
Scott , just grind off all the excess glass then somewhat feathering it back to finish up your layup in that area when tabbing your stringer to the hull .
Scott did you round the edges on the stringers? That might be why the mat isn't laying down. Just a guess. Once you bury the stringer in cabosil it will and glass in place you'll be ok. Great job!!!![]()
Yes, I rounded all edges with a router and a roundover bit. I even bought one of those rollers with the grooves that are made for fiberglass work. I just can't seem to get it to lay down on that small point. Another question. Is this the same glass I want to use to build my seat boxes or should I use the finer fiberglass?
The seem in the pic has wood below and something esle above it. Can anyone explain to me what is going on here? Only the bottom holes seem to be going through the plywood transom.
Robbie ,just curious where do you get these actual figures from when doing a standard layup and is that from many years of experience or just what you pull up on the net ? Robbie , i am not trying to be rude but i would not recomend that lay up to anyone on here considering .it can be done much easier (pre - made )and stronger then mentioned above ,and this info is comeing from a person who spells shoul wrong and uses carpenters glue.
For the rivets... take a nail punch and knock the rivet pin in so you can drill only on the aluminum body of the rivet to drill the head off. A 3/16" bit should be perfect. Once the head is off, you can knock the remainder of the rivet through. When the drill bit if full of rivet heads, use a pair of pliers and put the drill in reverse and pull the rivet heads off the bit.
Your next battle will be the sealant between the top deck and hull. I used a pry bar and popped it loose. To slide the deck forward, I used a 2x6 under the bow (spanning a couple feet beyond the hull on either side, so the deck will sit on it) a 2x6 under the transom (same as the bow) and I lifted from within the boat and slid it forward on the 2x's. It worked well... Oh, don't forget to remove the drain tube for the splash well prior to removing the top deck. Also, badbk and sam i am have good pics of breaking the seal on the the transom.
For what you mentioned above, I see no pic, but assume you are talking about the filler type product where the splash well is? once again, badbk and sam i am are going with a lipless splash well to avoid the filler.
Thanks for the tip. As far as the lipless splashwell, I want to try and keep as much or all of the original gelcoat. I could drill the holes for the jackplate lower on the transom so all of the holes are going through the transom and not the filler. I could then raise the motor on the jackplate to make up for the loss of height. If you look on the pics I just poste you can see the top holes are right at the seem. I guess I will know more once I get it seperated.
