You're becoming a little post whore.![]()
Also found a couple of Imperfections in the metals that may cause trouble down the road {ie... a small pin hole from someone using too long of a screw}.
You should be able to take the section to a shop that does aluminium welding and have it welded up and ground smooth.
Great work SRS !!! I look at the thread every day and really like what you are doing.
Since you seem to have taken every single thing apart , do you know how the Rear sundeck comes apart ? Let me explain The top cushion from the bottom fibreglass part ? Then hinges are all loose and would like to have them tighten back up
hoooooo BTW , I has a 221 since Saturday !!!
on purchasing one heck of a nice Checkmate --- when you get that Vision in the water and rigged up to your liking, I promise you will not be dissappointed -- these little 22 footers perform like real champs, -- they handle like a Ducati and turn heads like a classic hot rod.
Amazing ! Thanks for the info , I figured the Fiberglass may be soft where they are mounted and should probably back it up with something like you suggest.
I had to do that with my rear cleats on my Senator.
BTW our Gas shocks are not mounted in the same way at all ... Did you re-position them ? Mine have a terrible angle for leverage.
Sorry btw did not want to hijack the thread.
Kurtster;599534 All frame pieces disassembled ---- I safely stored and labeled the four glass panels ---- and I removed and labeled all the rubbers {the rubbers are all in great shape and reusable} [ATTACH=full said:
