25 centerconsole
i really like your project and want to see the outcome! looks really cool:thumb:
Ross, hop in the Ole' Dodge and head this way, you could run your boat in the dirty water and stop by to check out this build, drinks on me.
now we are getting somewhere
I agree with the others...very cool build. This thread has fueled my imagination. I've had fantasies of chopping up an old mate and turning it into a Musky Hunter. An old long deck would provide a lot of real estate for a huge casting platform and under deck rod storage.
Is that filler on the bottom of the boat good above , and below the waterline , and if so is it a 3-M , Adtech, or ........., and just curious ..seeing that you are from my home town ( Saginaw ) do you know Terry Robinson , or Bobby Dubbay ?
Post # 96 ( strakes ) as i look at your pic'c i am wondering what your thoughts are cutting the strakes back ..........considerig ....strakes are there for a reason .which means more lift , which means less wetted surface , which once again means more speed , and to tell you the truth that is a far cry from a stepped bottom ..if that is what you are trying to do , and can you explain !
it is polyester filler with red hardner good for anywere. the strakes were cut and that is why i had to fix all of this mess, they did a bad job and it was all bondo caused me a headache. might be alittle slower but should run alot better in rough water and when is it ever calm out. I do know terry and have winterized his cig a few times and i know his engine builder kyneth sp. peace out:p
