paulsboats
59 days till spring!Sounds like a good idea to this guy. I'm having a lot of fun. I'm starting to think I'm going to be board when I'm done with it. Or just use that time to go boating.![]()
Just finally got though your build pics. Your doing a hell of a job. Nice work. keep it up.![]()
I posted this on the paint part of overhauling forum but I thought I would post it on here also just to keep everything up to speed. I'm planing on painting the boat and would like to go with the original purple or match it the best I can. One of my good friends witch is a auto body teacher at a teck high school. He knows alot but not much about painting a boat. He told me that he knows PPG makes a bottom boat paint. I was thinking about painting the hole bottom in this. Then just matching up the purple metal flack from House of Coolers to spray on the deck. What do you think of the bottom all black and the deck just purple. Also the product choice or what do you recommend I use. I used epoxy for my layup also I think that would matter on paint but then again I don't know.
It looks like your boat has never been painted. How about gel coat? It's more work, but will hold up better than any paint.
This may help clear things up http://www.cruisersforum.com/forums/f55/will-gelcoat-adhere-to-epoxy-5794.html
I'm not speaking from experience, but I will consider this direction if get around to rebuilding my 72 MX-16. It's a lot of sanding and buffing but the result is a tough finish that can stay in the water. My boat will sit on a trailer most of the time and had been painted several times so I chose Algrip. I would use this again on the hull but I would use a base/clear finish that could be sanded on the deck. No matter what you choose, I'm sure the right people can match color for you, except those designated "bottom paints". It's looking good, keep the pictures coming.
