redstrat
i can't believe it's been over a month since I updated. I took on a boat interior to raise funds. It took all my spare time for a couple of weeks but I was able to buy a new aluminum rub rail and ordered a new windshield. I also have finished putting the power head back together. I spent hours cleaning gasket surfaces. I'm going to paint everything white before I put fuel lines and electrics back on it.
Yesterday I drilled all the new holes through the transom. I used a small brush and coated all the holes with epoxy. I also took some time to polish up the old stainless hardware. I wanted to put a brass drain in it so I made a flanging tool by taking the nylon out of a nylock nut and reversing it to make the flange. Once I got the flange started I used the washer to flatten it to the inside of the hull. Of coarse I coated everything with 5200. In the picture of the stainless hardware you can see a gasket that I made fore the tie down eye out of 1/8 inch closed foam. My thinking is that this will help seal the hardware and protect the paint. I also epoxied all the snap studs (70) to the floor for the carpet. I'm going to mount the setback bracket tomorrow and maybe start the rub rail. i'm a bit nervous about bending the aluminum. This stuff is expensive.
Have a great week everyone.
