This is where I stand as of yesterday. Had some minor issues to start with getting/keeping one of the engines running,but it seemed to work itself out after burning a little gas and started running great! The day went smooth and boat ran well, but cruising back to ran at 4K rpm's the starboard engine suddenly over revved like I lost a prop. I immediate pulled the throttles back to find everyone was intacted. I limped in on one engine and when I got to the dock I went to put the port engine in reverse, but had none! So I currently have two lower units out of commission. The starboard side locks the prop in forward and reverse but the engine does not drive it. The port locks the prop in forward but not in reverse. I will pull the lowers in the next day or two and see what I am in for.
Also, there is a drain plug in the setback bracket- when I got home I pulled the plug and it was basically full of water. When I pulled the hull plug, there was a fair amount of water in there as well. I suspect there is water leaking into the boat from the mounting bolts in the bracket, but I will fill the bracket with water and verify. If there is water getting in any of the penetrations in the transom, I feel like it means the transom is water logged. Time to change my focus from the cabin to the mechanicals...
I know it's always a craps shoot when buying used. However, a little heads-up about these things would have been nice.
It has been a long winter with NO progress made
The boat looks now exactly like it did in the last pictures I posted. I have made a few moves on the power plants after pricing out the repairs for the lowers - I found some decent priced 2008 Mercury Verado 300's. I am hoping they are here in about a week and half. I will be selling off everything engine related I have - Steering, controls, engines, setback etc.
The engines will get bolted to the transom or 6" jack plates. Still undecided. I am only going to finalize what I started in the cabin for now. I'll get back to that later in the year. Stay tuned![]()
