DropTop5.0
Boy that transom is a holy roller. Looks like we can play connect 4 in that thing. I think you have me beat in the Swiss cheese department. I'm loving all that fancy new hardware and can't wait to see it.
Spencer are you still going to do the pourable transom? http://www.carbon-core.com/carbonbond-transom.htm
I will be doing the pour in transom this coming winter. Out of time this year and it's time to go boating!
Going to hook a trailer to the trailer for them.LOl
No presure but one week.
I didn't get to play as much as I hoped this weekend. Had one issue with the charging system, but we got it worked out over beers and under flashlights
I ran a few props and liked the feel of the four blade 26p Bravos. Jumped on plane and was cruising the 55+ MPH range around 4500 RPMS. I did not do any high speed passes with these props but did see a max speed from a quick trip of 62 or 63.
I also tried a set of Hydromotive four blade 25 or 26p. I did not like them at all and made the boat almost uncontrollable. I saw a max speed of 69 but didn't push my luck since they made for a scary ride!
I put my 27p Merc Choppers back on and made a high speed run in good conditions and saw 76 mph at 61-6200. I think there is still a couple MPH to be had with these props - I could have trimmed up a little more and I had the tabs down a couple clicks.
All runs were made with 75+ gallons of gas on board, full gear and two or three guys on board. I am going to plug the top three or four holes and raise the engines an inch and go from there.
I think there's more in that setup. The Verado 300's max rpm is 6400 rpm. With some tweaking, props, etc. you could creep up on 80mph. I ran a best of 72mph gps with my stock 2.4's before I added the cabin back in. With the 2.5's and CLE's I've seen 66.55mph GPS. Looks like I'm going to have to step up my game..I might be rigging up a couple of 240hp Merc 3.0L's...
