ballardnboyz
yes those are the ones and the aluminun economy rollers will work just fine and stay away from plastic . Jeff if you get a chance go back to your thread on core page 3 post 30 on what i wrote about fabric and jeff not trying to tell you what to do but matt (chop ) is not compatible or recommended to be used with epoxy because chop is designed to be used with poly or vinyl ,and fabric such as #1708 that has a matt binder are sometimes used with epoxy resins with satisfactory results but the binder may cause clouding and sometimes prevent through wet out which means this fabric will take more resin then normal to wet out .
OG what size roller would you recommend?...and please...tell me what to do!! Thanks for all your help
....marine plywood needed $220.00...fabric, epoxy and tools $1200.00....all the help here...priceless!!!
...now i have to clean the shop
..i used everything heavy i had to weight it down overnight...the balsa stuck well....like i said time for lay up, the final layer of 17 oz....
 Jeff just curious are you going with one layer of 17 oz or two which i would recomend  along with staggering the layup .
