ballardnboyz
DAMMMMMMM ..................l@@king g@@d ...........Are you sure you haven't done this before ?Jeff just curious are you going with one layer of 17 oz or two which i would recomend along with staggering the layup .
thanks OG!..
Im going to put a build up of 17 0z bi-axle to get me even with the old roven, then going to cover and overlap the entire repair area about 3 inches onto the old roven all at once, then when dry im going to cover all the new and old balsa in the whole boat with 17 0z bi-axle...ill have about 20 yrds of 17oz. biaxle before im through...not including the transom...
the transom was laminated in 1708, then wrapped in 17 ox. bi-axle, then it will be laminated to the hull with cobasil and 1708, after clamping and a overnight cure, will then feather out all edges the with cobasil, then cover the transom and tie into the hull with 2 layers of 17 0z bi-axle....still leaving me the knee braces, stringers and floor. Did i say I wrapped the new 3/4 inch pad with 17 oz. too? Who said this would be easy????
