I'm thinking of the condensation that'll be trapped inside of the 'water-tight' box you're building. I think you're still supposed to have drain holes front to back regardless..............![]()
On the other hand that is why they rot in the first place. The water freely flows from the bilge and gets in there where it never dries out. That is why they had those slatted ski locker doors so the area can dry out.I'm thinking of the condensation that'll be trapped inside of the 'water-tight' box you're building. I think you're still supposed to have drain holes front to back regardless..............![]()
How does the moisture pass from the wood into the box or vice versa, through the fiberglass and resin encasing the wood?Even though all the new wood is getting covered in glass and resin, over time the moisture in the wood and the condensation inside a closed box is going to rot all that wood anyway....................![]()
I disagree about 'water won't travel through several layers of fiberglass' after all the pix of rotted cores I've seen, in areas where there has been no breach (like the screw holes Robbie had). Just look at the dozens of Hydrostream rebuilds where there was bad cores and decent fiberglass over the cores. All it takes is time. Even boats like ours that not only have several layers of fiberglass, but good epoxy paint over all THAT we can still get rotted cores. Probably all depends on how good a job the 'glass layers did when laying up a new hull.
I think that's why Allison has such great resale value, no wood to rot over time..................
Robbie,
I'm going to throw my 2 cents in here and also shed some light on the state of rot
Let me first start by saying I don't engineer plywood and I am not an expert in wood boat building(you know that, but hey, I guess I need to qualify for those who don't know me). However that being said; before I began my Enforcer resto I was only a few months away from starting a large wooden boat project( Tolman Jumbo skiff). I still plan on building this boat; but I won't try to tackle it for several more years. During my research, I accumulated a small library of boat building manuals. Here is what I have learned about building boats with ply regarding moisture.
Wood has to have a certain percentage by weight of water. Marine A; AB douglas fir should have 8-10% with 15% being the upper acceptable range. Hardwoods should have a little higher content 15% being the acceptable starting point. If you don't have the proper amount of moisture, the wood is weakened; either too brittle or will become susceptible to memory and warping.
Moisture at these levels are a good thing. They maintain the the strength to weight ratio's that make wood superior to most boat building products in both cost and workability. Most reputable boat builders that build with wood, will mantain that you should have no rot or failure issues with ply or wood that have these levels of moisture; as long as they are "properly installed and encapsulated".(note: I'll also add "mantained" here as well)
Key phrase; "properly installed and encapsulated". Epoxy is by far the superior coating for encapsulating wood on the market. It bonds more firmly than polyester and is generally more flexible without releasing. Because of these qualities, it is better suited to prevent excessive moisture and air(the deadly combination) to enter the encapsulation of the wood, due to the plastics failure; thus preventing rot.
The newer polyesters we use for boat repair have much better adhesion to wood than those in the past and tend to be less brittle. They are better able to encapsulate the ply without failure and release; but still not as good as epoxy.
Our checkmates rot problems are not due to the use of wood. They are instead due to failure of the adhesion between the wood and the polyester resin, thus allowing water to penetrate a much larger surface area of the wood; and also allowing air to be trapped between the glass and wood surfaces. This causes the rot! As long as the encapsulation remains intact and air tight with the appropriate moisture content; the wood will maintain it's integrity and be preserved. Have you noticed that when you remove a rotted portion of your boat; there is always seperation of the wood from the glass? The rot didn't necessarily cause the seperation. The separation was more likely caused by loss of adhesion; the encapsulation was breached; water and air were introduced and rot ensued. Decay eventually completed the seperation.
Another example of the relationship between water, air and rot is the recovery of vintage logs off the bottom of our rivers and shipping lanes. Those logs have been submerged under water and mud between 75 to 150 years... saturated and encapsulated. Why are they not completly decayed? The answer is the lack of air. Wood pylons for docks don't decay nearly at the rate as they do at the water line.....the answer? introduction of air. basic principles of bilology, oxidation and decay.
I know this is long.....the point is, if you are getting good adhesion to your wood and encapsulating thoroughly; the ply you are using should last you a lifetime or longer. Take care when breaching repairs ie: drains; fasteners etc. be sure they are carefully and properly resealed. When I look carefully at all the rot on my Enforcer; release of the polyester from the wood and breaches to the encapsulation were the biggest culprit in the rot of my boat. Couple that with excessive saturation and entrapment of air make for the inevitable.
So based upon the above; fully encapsulating your boxes w/o drains should not be a big issue as long as the "tub" you create dosn't have installation flaws or any impromptu breaches down the road. But, you don't want a potential "tub" in the middle of your boat. I agree w/ JW in that you need some drains installed(you might check out Jupiter Pulsares thread on his stringer and floor replacement; the drains he installed were very impressive) be sure to adequately glass any drain holes so as to prevent a potential breach.
Second, If you are using a good quality Marine/Exterior grade A or AB plywood; and have kept it in a dry area; your moistuer content should be exceptable.
Sorry again for the long post. I hope this helps and I hope I havn't offended anyone.
Hick
FYI I didn't choose the coosa because of it's low rot resistance(I'm not completely sold on that); I chose it because of it's weight and better adhesion to polyester.
If anyone wants to know my reference material they should check out:
"Boatbuilding with Plywood" By Glen L Witt. 3rd edition.
"The Dory Book" By John Gardner.
" The Epoxy Book" West System Three Publication
"From a Bare Hull" By Ferenc Mat'e
A.P.A The American Plywood Mfg Assoc.
if these don't convince you; pull out a highschool biology and organic chemistry book.....basic organism /enzyme decomposition and chemical oxidation.![]()
As I was reading through your post the first thing I thought about was the river logs and how preserved they are.Another example of the relationship between water, air and rot is the recovery of vintage logs off the bottom of our rivers and shipping lanes. Those logs have been submerged under water and mud between 75 to 150 years... saturated and encapsulated. Why are they not completly decayed? The answer is the lack of air. Wood pylons for docks don't decay nearly at the rate as they do at the water line.....the answer? introduction of air. basic principles of bilology, oxidation and decay.
Hick
