No, the foot throttle won't interfare with anything. It was carefully planned and measured out. Remember, there are no manual cables..just a plug in harness because the Verados have digital shift/thottles..
Right ... DTS
Yes I can see how sometimes a chine walk could initially be though of a a porpoise but there's no mistaking this high speed porpoise, I've had Allison, Actions & Shadows 16 footers through 21 footers & have raced a few races in my time & scared my self a few times while learning to drive through some nasty chine walks to down right getting a blow out but I'm still going to get a couple buddies of mine that definitively have more experience than i & have them drive my boat to see what they think; thanks Nastybug I appreciate the input.
System checks OK
would love a set
Unfortunately the templates I made got cut up for some other projects, I can send you some close up pics & measurements of the outside plate & inside box if you want.
I still have the inside template in my garage. I never used it as I came up with my own transom savers..
Ahh nice, cool lets see what Stimleck wants to do.
Hi!
I have a Phantom 25 feet offshore hull. I have done several engines on her, incl Johnson GT 3.6 300 Offshore, Promax 300 SVS, 2 x 2,5 EFI SS Brucato and Verado 350 Sci. I have a 400R on order for deliverance April 2017. It will have Sportmaster LU with cambered skeg.
I have experienced problems with the power assisted Verado steering. Its not precise enough. The "slack" in the steering makes it difficult to run the boat fast. Top speed with the 350 Sci has been 81-82 mph. This is with the standard HD 5,4 gearcase.
How are your steering on your 400R? Are you satisfied with it? I have lost my bowlift at wot sometimes, causing the boat to drop hard on one of the sides. Not fun in 81 mphMy boat is very narrow. Only 5,5 feet.
Hopefully the sportmaster will be better at elevated transom heights and the top speed I am aming for. The HD gearcase neither like high speed og high propheights.
Cheeers, Toffen
Hi!
Cheeers, Toffen
