Jimway
Unsubstantiated rumour around here is that Hudy will be driving the Heat on it's shakedown { or maybe shake up } cruise. It has been said that the neighbors daughter is very attractive, apparently at the level of Smoking Hot{ SH } I suggest reasonable caution in this area. It has been shown that contact with the Smokin Hot {SH}, under the right conditions, even just innocent talk {IT} can lead to some rather uncomfortable conditions later {such as in stepping in ****, or being in deep ****, or bein hit by some ****,etc.} I have actually seen Smoking Hot Significant Others actually become smoking hot which normally should be avoided. If your significant other should become Smokin Hot, you may experience loud, shrill, voices that may hurt your ears{ making sleep difficult too } The heat waves radiating from your SHSO, along with the laser vision that will be directed at you, may burn the exposed skin. Objects and artifacts lying innocently around may become projectiles aimed at your general direction, which can result in bruiseing and contusions and even fractures depending on how significant your significant other really is. Always best to avoid this kind of behavior, I'm just sayin...
and I know I shouldn't ask but I can't help it, What is this black hoe altitude adjustment? I'm gonna go out on the limb and guess that the Tahoe is becoming closer to the ground?
