Dumb question, but are you putting foam back in? or better yet is there a purpose to the foam?
The foam is there to keep the boat from going to the bottom.
A little more on the stringers.... The original stringers are made from 1-1/8,
No one in the area has 1-1/8 plywood. So I decided to make it out of 3 sheets of 5/8 that run top to bottom. Apparently Checkmate likes to build with overkill and so do I.The wood is cut at a 45* at all the joints and they are staggered so no one joint is closer than 24" The 45s are to the right on the center board and to the left on the outside boards. They are glassed together with 1-1/2 oz mat.
eh, that's what insurance is for.
So do most people put it back and or what type do they put back? Is there any that doesn't absorb water?
P.s. JIC, the project is looking amazing. Can't wait to see the finished product![]()
The stringers for connecting the main stringers and front box are in.
I'm not using foam so I am putting 5 ribs in per side to suport the floor. Cut the ribs to fit and laid a flange on what will be the top for better adhesion to the floor. They also have two coats of resin and the dreaded cloth where the the water Chanel is. I will probly bed them in and put two layers of tabbing on them too.
This is a great idea. I'm also not adding the foam back in and will think about adding a couple of small ribs.
My floor under the tank was completely rotted and I'm thinking about not adding it back in. I don't think, on my boat, that it really serves a purpose.
By the way your glass work looks really professional....I wish I had that kind of skill. I keep getting air bubbles popping up as it cures.
