Wow, if you are going to glass the deck anyway, why not roll on non-skid in a pattern, paint it and lay in some (snap-in) carpet? Glued carpet is a cheap way to cover unsealed decks. You've spent the time and money to glass/seal it. Are you going to tape the edges so water can't run around it by the hull?
You're reading my mind, GW. I'm going to use a product called "Tuff Coat non-skid coating from Overton's, I'll go with a gray since my carpet is dark red. Then add snap in carpet later. Here's the link:http://www.overtons.com/modperl/pro...ing_gallon&merchID=1008&str=73213&from=search
Ever thought about a sump/drain to route the water to the bilge? I hate the way there is no path for water to run off the deck into the bilge to the pump. I've thought about glassing in a dam/drain tube right to the pump area so it doesn't run all under the rigging, batteries, fuel tank.
In the back where the knees and floor meet I'll cut slots to help the water drain to the bilge area. I'll show a picture once I've got the floor in.
My batteries and oil tank I'll do the same thing that I did with the Pulse170 resto. I'll add pads underneath so water will go around not under them. My fuel tank is under the floor, so still working on getting that seal up around the hoses and sending unit.
My solution now is lots of towels when skiers/swimmers get in. My bilge will never get wet unless I get caught in a T storm.
Nice job by the way. You don't seem to be slowing down.![]()
You are on a mission, man...Nice job. That boat will be better built than when it came from the factory.![]()
Serious, call me when your about ready to do paint work and I will come down and help a brotha outThen prep the transom for painting, hopefully I can match the color or at least come close were it isn't noticable.
Serious, call me when your about ready to do paint work and I will come down and help a brotha out. Sides, I am always looking for a reason to get out of dodge.....aka cincinnati!
You're welcome to stay for a few days as well, it's warmer down here.Wiring would be my specialty![]()
