Ok just thought I'd ask , if you put that additive in when you shoot the next time it will prevent any fish-eyes from starting even if there is some unseen oil or silicone that you can't see. just tryin to help. I had a set back fired the motor up today and it's ( real throttle responsive ) but the water wasn't circulating when I put the lower unit on some how the rubber gromit in the empeller houseing ripped and half way blocked the water tube off, so I shut it down and pulled it off and found the ripped groment, I was *#%*@ mad at myself for being empatient when I put it together and not put a new water tube in, it had a small bur on it I didn't see. Can you test the tempeture sender in the heads?? I have a new gauge and new wireing and it's not reading???? I'm proud of the engine build it is responcive and shakes the whole boat on the trailer when rapped up to a quick 6,000 rpm175checkmate said:Spent Monday night sanding off the yellow and the black. Got about 1/2 the boat done. Have to get the other half sanded off. That won't be until at least Monday. To dam hot here right now.
Reed, all the paint stuff is from the same company. I still think it was contamination in the paint can. I should have opened a new can.
cooperider said:Haven't we been here before?
