I have a 1987 251 Convincor. I am running a 454 stock block punched out .060 over to make 468 c.i. with cast iron merlin heads with Jim Valako (Valakoraceheads) wedge port job done to the intake ports and a dart high rise intake with wedged porting matched to intake ports to increase flow velocity. Full roller motor with crower roller rockers, Ferrea valves, hydraulic lifters, engine pro big diameter rods, stock rods, 4 bolt mains, .010 under journals on the crankshaft, .584 lift hydraulic camshaft, forged TRW domed pistons with valve relief, about 10.5:1 compression ratio. I am using a holley 850 double pumper modified to flow 880cfm. I also am using lightning headers with switchable exhaust tips to quiet the bark in the no wake zones. MSD blue box marine ignition with rev limiter set at 5800 rpm right now in case of airborn antics or a drive failure. I am also running full imco hydraulic steering from the helm hooked to a bravo one with drive shower, no nose cone yet - still doing research to see if it would be beneficial. I am running a 25 pitch 4 blade stainless hydromotive cleaver prop most of the time, better for getting on plane and almost impossible to blow out, on occasion I try my 27pitch 3 blade mercury mirage prop but that seems very prone to cavitation and blow out. The motor dynoes at 600 hp without any supercharger or procharger. Bennett trim tabs right now, K planes would be better. My best gps'd speed was 78 mph at 5750 rpm, driver only and light fuel load, will do 70 - 72mph with a boat load.
78.5, full tank, 26 trophy, 5900RPM. Going to try a fury and Bravo I XS later this year think I can get into the low 80s easy.
"Faster". Always faster.97 Persuader 219 w/ Procharged 7.4/bravo 1 w/ cone turning a 28p bravo. I haven't gps'd it yet, but I can bury the 80mph speedo at 4600rpms. Stock engine w/ Procharger. I figure around 450-500hp. Any thoughts on how fast this boat should run?
