Sam I am
Progress!
Decided to remake the transom 2" taller tonight. Took me about 1 hour since I simply traced the old one and added 2" to the height. I was able to run the new transom through the table saw and take off material around the edges here the factory built up the hull when laying the hull. I also discovered that you can shape this material with a hand plane, which really led to a nice fit and a lot less mess then sanding. After I got done shaping I ran the transom around my router table with a 1/2" round over bit. A little more sanding and she's done.
Also, I repaired the crack in the stern with epoxy and two layers of heavy interwoven glass on the inside of the crack. After I got that repair finished I set about making my transom clamps per the plans the cmpulse posted up...although they might be old hickory's plans. Anyway, they should work like a champ. After the transom is in I'll them repair the exterior of the stern and glass over the entire stern.
Tomorrow, the transom will get cab-o-silled in. My plan is to mix the cab and the resin first and then add hardener after I get the right quantity and consistency of paste. Clamp the transom, fillet the edges and base...go to lake and drink BL Lime and try to trick a fish or two.
, no wonder why you have less than 20 minutes pot life. I believe the 23 minutes on the 3:1 medium is at 70 degrees or there about. I am fortunate enough that all my work has been done under 80 degrees so far.
