Sam I am
That has to be about the end of demo, right?
Not quite...front stringer is still glassed in and I need to get rid of all the foam in the front. After that it will be time to start grinding and sanding.
Curious if you have tried cutting your composite material yet, and how hard it is?
Sam after viewing your pics in post# 125 i can not believe all the DBF that Check used in there build when doing a Transom .
That's the "bondo", right? What does DBF stand for? It makes an awful mess when sanding and grinding, that's for sure. But, it apparently sticks like none other...
Detroit Body Filler which is commonoly used in production boats and sold by the drum .That's the "bondo", right? What does DBF stand for? It makes an awful mess when sanding and grinding, that's for sure. But, it apparently sticks like none other...
Nice work getting the transom out! I wasted 2 hrs before I was told about popping it out!
Got busy today and made the transom out of the thermo-lite composite material I picked up from SpaceAge Composites here in Fargo. http://www.spaceagesynthetics.com The material was dark gray, almost black when I picked it up but as I had stored it outside on a trailer, the black dye is not UV resistant and faded to light green/gray on one side. NOt a big deal, but I thought I'd mention it.
Sam
What did a sheet of that stuff cost?
